Would you consider 400 watts max a lot of power? Also, do you put a screw and washer through the coax braid?
Where do you guys buy yours. Saw some on Ham Radio Outlet for 25$ good price or have you guys found cheaper?
Since RF travels only on the surface of grounding straps, use only 1" wide straps or bigger.
I was thinking about using some NO-OX-ID on my metal to metal connections like I did on my A99 joints. In the past I've always painted over the fresh connection with matching paint to seal the union from the elements. That's my preference. I've seen how bad a connection can rust and corrode.
