Broadband antenna for rx only
Need2Know
KK4GMU - Ocala, FL
Jan 26, 2012
144
13
Ocala, FL
www.muccings.blogspot.com
In understand that the stock antennae on most HT's provide minimal performance.
For the Kenwood TH-F6A, (receives 0.1 through 1300MHz), what antenna or antennae would produce significant improvement below 100MHz short of going to an outdoor antenna? I will have a dual band attic mounted J-pole for 2 meter/70cm.
Are there any recommended radio-mount antennae that would result in significant improvement over the stock rubber ducky?
Anyone with experience with in-room mounted (semi-)long wire for receive only?
Other options, e.g. in-room long wire with antannae amplifier?
Experiment.
On my first receiver, circa 1958, I used a piece of 22ga. bell wire running diagonally across my bedroom ceiling, then down to the antenna terminal. Maybe 14 feet altogether. I heard just about everything from AMBC up through the ten meter ham band, and I heard it well enough to accumulate a few hundred SWL QSL cards before I got my Novice license.
I've never used the TH-F6; I wouldn't think it would be as good as the old Hallicrafters for MW and HF.
But, to reiterate: experiment.
Sure, I did that when I had that same radio. It will definitely help. Another one you might look at is building a magnetic loop
A magnetic loop for receive only like this one?
A Magnetic Loop Antenna for Shortwave Listening (SWL) - KR1ST
What are the input gain pattern over the range of freqencies handled by the F6 on various length "long wire" antennas? Do variable capacitors have a similar effect on long wires as they do on the magnetic loop exaample above?
Have you applied variable capacitors to long wires?
  • @ Mark Malcomb:
    Hello BJ. Been a long time since I've been on. You doing well? Mark Malcomb
  • @ Naysayer:
    I’m
  • @ kingmudduck:
