Browning eagle mark 3
Discussion in 'General CB Services Discussion' started by wavrider, May 20, 2013.
  1. wavrider
    wavrider
    Expand Collapse
    Jun 2, 2009
    3,150
    901
    Got one gave to me a few weeks ago at a ham fest.
    Got it up and running, aligned it as per instructions from CB tricks site. ( great site).
    I have the PAL model 90-3 vfo and have it wired into the TR.
    Need any info on broad banding the receiver.
    Also any type of mods for this old tuber.
    I do know about strapping the bias resistor on the tube final, I removed that when I put the rig back to factory specs. Not looking for any power mods, just any improvements on both TR and RX.
    B Wolftalker and n0zna like this.
  2. peterwo2e
    peterwo2e
    Expand Collapse
    Apr 3, 2013
    11
    as far as receiving i concern this radio has one of the best receivers that i have ever came across as far as cb radio is concern. this bird is old and you might have to send it to barket electronics. hope i got the name correct. anyway my mark 3 is about 3 watts dead key swings to about 15 watts with the stock desk mic it has loud clear audio the pinger is out of this world with a x-force 40 amp. it dead keys about 40 watts swings to 100 watts into my alpha 86 (not use all the time) this set up would give me about 700 watts dead key and swings to 1700 audio watts with out breaking a sweat. by the way when the pinger comes on it does 2200 watts. with my siltronix vfo i go up to channel 85 and 3 channels below one. sorry i can't help you with your original question but im just giving you some idea what this combo could do once is set up right. once you get this bird tune correct and 100% don't let it go cause not all birds are created equal. good luck and enjoy that classic toy.
  3. wavrider
    wavrider
    Expand Collapse
    Jun 2, 2009
    3,150
    901
    I have the siltronix model 90-3 external vfo.
    The frequencies sound correct as for band spread.
    How did you broadband the transmitter to transmit on that much of a band spread? The original design is 23 channel.
    The receiver is separate and the model 90-3 vfo only connects to the transmitter.
    you have all the frequencies in the transmit side but how did you get the receiver to broadband enough to receive that many frequencies.
    Just curious as the only info I have is the factory service manual from CB tricks.
    The one I have keys around 3 watts and swings to 10 watts an an Autek true PEP reading wattmeter.
    thanks for the reply.
  4. grimace
    grimace
    Expand Collapse
    Sep 15, 2005
    94
    4
  5. w9cll
    w9cll
    Expand Collapse
    Jan 19, 2013
    2,885
    1,502
    The Browning Eagles were the cream of the crop of 11 meter radios along with the Tram d201. They are, as I have said here before, Ham radios in deguise.
  6. wavrider
    wavrider
    Expand Collapse
    Jun 2, 2009
    3,150
    901
    Having a lot of fun with that old bird.
    Ordered and installed the 40 ch receive kit.
    Works great but the vfo dial does not exactly align with the channel indicated but it is close enough.
    I aligned it at ch 1 and by time you get to ch 12 the vfo dial displays ch15.
    Sensitive receiver and the transmitter is great also. Of course it is a Browning.
    The rest is cosmetics. Just received the Browning Eagle in the mail today thanks to another forum member. Thanks Fixer.
    I will attach the speaker cover, the speaker grill and the eagle and that will complete the old Browning.
    I am using a Shure 450 mic. My Shure 444D is wired for the Swan 700CX, and the Other Shure 444D is on the Yaesu FT 890.
    Thanks for all the replies.
Share This Page
