I have a bruiser 100 ab class amp it powers up but have no remote need some help on how to wire it up. Any help is appreciated
here is a pic I wish it had the remote with it but I got it for free cause it didn't have the remote. All I would really like to know is what to wires go together to turn it on and is the second set of wires to turn on the ssb I'm new to amps and would like to try this behind my grant xl on ssb If I wasn't married I would've got rid of it by now but have no money right now and if I can get it running it will be a cheap amp to play with. Thank you
should the relay click when i turn it on.
It either has a preamp or the 2nd contact in that relay switches on the biasing at powerup which I don't care for but it may be tied through the keyup relay also which would be fine.Nope.
Only if it has a pre amp and it's switched on when you turn the amp on.
The keying relay should only click when the amp is keyed.
to do that hook up some power and use your volt/ohm meter and find the negatives and positive contacts through the multi pin socket.Well Thank you for trying I guess Im just going to hook it up and use a jumper the most i can do is blow it up i got it real cheap and i can't find anyone who knows anything about them.
