CA-72 pictures
caspear1978
Jan 8, 2009
84
45
Does any one have a Cobra CA-72 they can open up and take a couple of pictures for me?
I am having a problem with mine as it seems like its got to much gain on it, picks up to much back ground noise causing it to squeal pretty bad.
The mike worked perfect one day and then the next it started squealing. I haven't touched anything inside the radio to cause this problem and haven't touched anything inside the mic.
I'm looking for a picture of the PTT switch and also the pot to make sure the wires are in the right spot. also need to find out what size cap in on the pot so i can order a new one incase this is the cause of my issue.
Thank You in advance, Mark
