Carl Built
My CarlBuilt 200HDC amp with 2879 hg C transistors in it, SSB bias and SSB delay has this sticker on the back of it.
How do you decipher this direction? Not sure where the commas should go.
Is it saying I should set the radio's deadkey to an output level that will generate a max dead key of 100 watts on the amp? But if the dead key is 100 watts how does that line up with a 80 watt peak?
I think I will try pinging the builder directly too to verify if it is safe to use the Anytone's 60 watts PEP on SSB when the radio is connected to the amp but the amp is not turned on. I know RM Italy amps can't do this, at least the less expensive ones.
One thing for certain is keeping the SWR @ 1.5 or lower. Yes, call the folks at Carl Built because I purchased an amplifier from them about three years ago and I was as confused as you are. Tell them what radio you are planning to use with the amp and they will be more specific. They usually answer the phone up to 8PM.
Reactions: TimmyTheTorch
What he's saying is your maximum peak input drive should be 80 watts. Or less
I have no experience with the RM brand filter but I had a para dynamics years ago that had little affect on filtering anything at my old home. I picked up an old Bencher YA-1 low pass filter. Much higher quality unit that actually filters..
I ended up trying this exact Bencher YA-1 low pass filter on the same amp setup as I had with the RM Italy 27/586 low pass filter and I had the exact same problem i.e. when I un-keyed the mic the S-meter was pegged. One try was enough for me. Experiment over!
The new fan I installed in my 200 HDC is a lot quieter than the one that came in it.
I also replaced the 8 gauge wire with longer 6 gauge so I did not have to do any splicing etc. It was a great excuse to replace my quite dead 40 year old soldering gun with another basic model. I am using a Ferr Rite mix 43 clamp-on over the positive cable where it enters the amp case. And a circuit breaker.
Make sure you place the filter on the output of the amp, before the meter
Are the covers on the carl built amps riveted on? I just ordered a small one pill and im gonna change out the ugly stainless steel looking hardware to black. I cant find a side pic but at a front side angle i swear it looks like a rivet.
My 4 pill is also screwed on with 8/32 machine srews
I am having a slowly growing high SWR issue with my 200HDC amp (running at 14.5 volts) turned on high that gets worse as the frequency increases from channel 1 to 40. The SWR on channel 1 is 1.1:1 with the amp off or on, on channel 40 it is about 1.4:1 with the amp off and 2.5:1 or higher with the amp on high. This increase does not happen when using a dummy load. I know the best step to take is to take the Maco V58 antenna down and re-tune it, which is one thing I will be doing as part of putting up my M104C once the weather settles. In the meantime, I have checked all the connections and patch cables but no smoking gun.
I currently have one Fair-Rite 0443164151 Split Core Ferrite on the positive lead going into the amp and one where the RG-213 coax connects to the antenna connector on the back of my Daiwa CN-901 meter. All bonding and grounding remains in place. Is it worth trying multiple ferrites on the RG-213 or moving it to a different location on the coax?
I am also getting some reports of a bit crunchy modulation too using the amp with both the Q5N2 and the Lincoln II+ regardless of input power or modulation levels but so far the folks telling me this are not using "cheap" amps like the CarlBuilt. I don't think anything has changed so I am definitely not pointing a finger at the amp. Funny that "cheap" is not what came to mind when I was completing this purchase.
#Update: It stopped raining long enough for me to go out and temporarily replace the MFJ-272 lightning surge protector with a barrel connector. It seemed to help improve the SWR situation. More SWR testing to follow.#
Sounds like the input tune is going/has gone to crap
Reactions: loosecannon
    May 15, 2024 @ 14:55 UTC
    Everything is El Dead-o. Joy!
