CB base station antenna question
Discussion in 'CB Antennas' started by NF822WNY, Sep 12, 2017.
  1. NF822WNY
    NF822WNY
    Expand Collapse
    New Member
    Aug 4, 2017
    39
    17
    I currently have an Antron 99 for a base station antenna but have recently bought a used super perpetrator antenna and was wondering how close i can put these two together? They wouldn't be running at the same time i would install a coax switch. I would rather have them both in the air but if i have to i will switch them out.
  2. undertaker
    undertaker
    Expand Collapse
    Undertaker
    Apr 5, 2006
    1,575
    408
    I would get them far apart as possible. I did the same thing and it worked. BUT I had them far apart.
  3. NF822WNY
    NF822WNY
    Expand Collapse
    New Member
    Aug 4, 2017
    39
    17
    Yeah that's what i was afraid of, i will probably test this used SP out and if it performs better, which if should, i will swap it out.
  4. Robb
    Robb
    Expand Collapse
    Yup
    Dec 18, 2008
    10,449
    2,184
    Perpetrator - or 'Penetrator'?
    Use the Penetrator and save the A99 for a rainy day or camping.
    Meglotron, Ranch55 and Blackcat630 like this.
  5. Riverman71
    Riverman71
    Expand Collapse
    Nov 12, 2013
    971
    343
    "Perpetrator" if running a radio with a clipped mod limiter, power mic turned to maximum, and a dirty amp. :D
    fourstringburn likes this.
  6. silver devil
    silver devil
    Expand Collapse
    BANNED
    Dec 11, 2010
    159
    47
    at least 36' apart....
  7. Ranch55
    Ranch55
    Expand Collapse
    Jan 18, 2016
    105
    36
    Definitely the Penetrator 500 ....... You will need to "tune" the Penetrator for the 11 meter band. Mine ended up at 22' 6" in length from very bottom to top of vertical.
    20' apart measured from center of antenna to center of antenna will be just fine, as long as only one antenna is used at a time. Disconnect coax going to unused antenna.
    As stated above, 36' apart if not disconnecting the unused antenna coax.
    NF822WNY likes this.
  8. silver devil
    silver devil
    Expand Collapse
    BANNED
    Dec 11, 2010
    159
    47
    Nothing wrong with either antenna but please note that the P 500 will go up in SWRS when it rains or is damp out..
  9. Meglotron
    Meglotron
    Expand Collapse
    Mar 7, 2011
    52
    10
    i wonder if something like flexseal spray would stop that sprayed all around the base and coax conector. maybe yours was getting into the coax not the antenna.dont seem right theyd build an antenna to go up in swrs when it gets wet
  10. Staybolt
    Staybolt
    Expand Collapse
    Mar 20, 2013
    294
    43
    I have tried everything. I have owned several p 500 penetrator antennas and they all had the same problem. I also own several other aluminum antennas with coils in the bottom that all go nuts in moisture. I ended up giving up and i bought an i maxx 2000 and dont have any rain issues.
  11. Ranch55
    Ranch55
    Expand Collapse
    Jan 18, 2016
    105
    36
    Yes, my Penetrator 500 does raise the VSWR reading when rained on. But, not by a bunch. My VSWR stays below 2.0 ......
    All my connections are sealed with self sealing silicone wrap, and that is sealed with Super 88 all weather tape.
  12. The DB
    The DB
    Expand Collapse
    Aug 14, 2011
    1,636
    709
    All antennas with an external tuning circuit (that is all aluminum antennas that I am aware of) will have a small change in tuning while wet. The slight increase in SWR just because of rain on such antennas is no big deal, certainly not enough to be concerned over, and it will go back once said water evaporates. Their is no need to worry just because of this minor effect...
    The DB
    Ranch55 likes this.
  13. tba02
    tba02
    Expand Collapse
    WOOF
    Jan 26, 2014
    529
    292
    DB - an M400 "Starduster" is aluminum and has no matching components.
  14. Staybolt
    Staybolt
    Expand Collapse
    Mar 20, 2013
    294
    43
    Yeah but its only a 1/4 wave.
  15. Meglotron
    Meglotron
    Expand Collapse
    Mar 7, 2011
    52
    10
    if you have 9 feet going up and 9 feet going out as radials then you got a 1/4 wave but when the radials bend down isnt that a 1/2 wave?
Share This Page
