I don't understand this, but that's what you guys are here for. Here's my story:
I first got my CB a month or so ago, and was only getting a half a mile or so of range. I knew this couldn't be right, but never had time to fix it. Well here recently, my antenna was sort of knocked off it's mount by a railroad arm (long story...) and when I put it back on I changed the coax cable too (since someone had told me the cable may be shorted out, giving me no range). When I did this, I had NO range, not even any engine noise, and my mic power (I have a midland 1001z, it shows your mic's broadcasting strength) was at 2 out of 5 bars, when it was always full before. Well, I thought my radio was busted (hence the bad signal) so I went and got a new radio from Walmart (just to test it, I wasn't going to pay shipping both ways to send my current CB to the manufacturer only for them to tell me it was not the radio's fault) and low and behold, same thing. So, I'm certain it's my antenna....but honestly, how could the antenna be the problem? I mean, it's essentially just a stick with wire wrapped around it, right?
My setup (not meant for a thousand miles of range, just 3-5 would be nice):
1995 Ford Bronco
Mount is on the rear tire carrier
4ft fiberglass whip (grounded to the truck via a 12ga wire) with half of the whip over the top of the truck
Midland 1001z with stock mic
Originally 18 ft coax (unsure of shielding %) and now a 20ft 95% shielded (copper too)
What the hell did I do wrong? I thought this would be easy for me but I am sadly mistaken.
1995 Ford Bronco
