My buddy has got an older peterbult and wanted me to fix his coax and tune antennas. Both of the pl259s at the antennas had the coax ripped out of them. I cut the coax back about four inches to find good clean wire and braide. Put new pl259s on them. I cut the same amount of coax off both sides.
I then used my antenna anylizer and a single piece of coax that ive made going with the math and velocity factor of the coax to get the most acurate readings. After tunning both antennas to read 1.2:1 i then checked swr in the truck at the radio connection and im seeing a 1.8:1.
Any idea why this is? Did i do wrong by cutting the co-phaze coax? Should i tune antennas by putting anylizer at the feedpoint and cut antennas the same on both sides at the same time then takecanotger reading and continue?
Any comments are welcome.
