The power handling ability of any/all coax depends on the antenna at the end of it, how well it's tuned. If that antenna is well matched, and atleast sort of resonant, then the feed line can carry more than you'd thing. If that antenna isn't well matched (impedance/SWR) or at least sort of close to resonant, then some of the power being fed to the antenna never get's to it, stays circulating in the feed line, which will lower the power capability of that feed line. In really extreme cases, that circulating current/power turns to heat, and/or raises the voltage to a point where the coax either get's too hot (not real likely) or arcs over (the biggy). The coax spec charts used to list the break-down voltages, they don't any more, just the 'typical' power handling abilities which is supposed to make things 'simpler'. Another aspect is that the manufacturers tend to be a bit 'conservative' in that power handling thingy, which is pretty easy to understand.
So there's no 'set' answer for that question. Paying attention to the manufacturers specs is a good idea.
