Cobra 148 gtl dx ss360fm pb010ab wider audio mods tx Rx
Abikerlad
Mar 15, 2013
24
3
13
When comparing the pb010ab Cobra to the later anytone 5555 etc there is a much fuller sound coming from the anytone, the old pb010 cobra has the bass rolled off compared to the fuller sounding anytone.
I see there are some Hi Fi tx Rx mods for other radios is there any for this?
TX ONLY
C150 .22uF/25V to 2.2uF/25V Tantalum
C143 .1uF/25V to 2.2uF/25V Tantalum
C144 2.2uF/25V to 2.2uF/25V Tantalum
C221 .022uF/50V to 2uF/50V Mylar/Plastic Film
C223 .047uF/50V to 2uF/50V Mylar/Plastic Film
Plastic Film Capacitors
Tantalum
  • cobra_148_gtl_dx_sm_pg33_34_sch.pdf
Reactions: 4 people
RX Mod
C39 .022uF to .001uF Mylar
C40 .1uF to 1.5uF Mylar
C42 .01 to .1uF Mylar
C181 1uF/50V to 2.2uF/35V Tantalum
C175 .01uF to .001uF Mylar
C167 330uF/10V to 680uF/25V Electrolytic
C173 22uF/16V to 47uF/25V Electrolytic
If you replace the microphone pre-amplifier with a better quality opamp your tx audio will be improve
Replace 4558 with NE5532 op amp
Reactions: 3 people
RX Mod
Thank you so much did most of the bass ones as don't have all the caps yet but it's transformed it lots.
TX ONLY
C44 2.2uF/25V to 2.2uF/25V Tantalum
Tantalum
On the tx side are you sure about c44 it's a 10uf electrolytic stock?
I am still hearing lots of bass roll off is there any place I could take a low lovel line out before it goes through the audio amp? Also a way to tap into the mic input bypassing any restrictions that are robbing the low end sound.
As mentioned here on this other radio.
http://www.mauldroppers.com/showthread.php?16572-Super-Wide-amp-flat-148-2000-Grant-receive
Use a 2uF Mylar 100V Capacitor to tap Line Level to R290 and R291 juntion lifting C223 for TX on AM only
For SSB TX Only lift C143 and tap Line Level to Pin 1 of IC3 using a 4.7uF/25V Tantalum Polarized Capacitor(Observe Polarity) + side goes to Pin 1,- side goes to Line Level Input
Do you have a wide receiver? or how do you measure your TX audio bandwidth?
I have an sdr I can see the tx bandwith it's 5k with teardrop astatic, will try with audio gear later when I make up a lead to tx and feed audio in.
