you put it on MA as the specs calls for.
TP9 is the driver bias point, and TP8 is the final bias point. It is all in the manual link I posted yesterday.
You will find two wires (TP8 & 9), usually purple and green that have push-on connectors at the +8v junction on the board, found here in this picture:
I just reviewed the SM for this radio, and it explicitly says TP8 & 9. Not to mention, I have done this about a bazillion times. Don't know what you are reading, but you should re-read it before you bust a move.
The DMM setting should be on 'mA' . . .
If set on m how do you plug in yer probes?
