Cobra 2000 GTL wire location question?
Crambone
Well-Known Member
Jan 22, 2019
506
159
53
55
I’m looking at a Blue wire connected to the main board and it’s running to MB3756 Voltage Regulator? Is this normal?
where does it normally run?
Per mine, it goes to the clarifier pot from below r44. 16903113939397939380764116780618.jpg
You have straight 8 volts on the regulator going to your clarifier circuit. Not supposed to be that way, my guess is someone has modded it.
Thanks guys, also found this brown wire cut coming of the switches any ideas?
