Difficult explanation...I'll briefly describe symptoms and skip to the weird stuff.
TX modulation drops to nothing after a few seconds of keying.
RX audio is faint, though the meter shows RX is working. Sounds like it's off frequency but isn't.
Turn on SoundTracker and it improves the RX audio but not the TX modulation.
ST red led bulb won't light up but bulb is ok.
Here is where it gets strange. If I press the SoundTracker button really slow, at some point, the light will light up red; and if I just hold it at that point carefully, it'll stay on and (ready for this?) all radio problems go away. As long as I press that button about half way in and hold it there so that red bulb stays lit, the radio transmits and receives perfectly. Replaced button w/ working one but it's not the problem. Also replaced channel/display boards.
