i have a 3300hp that i was trying to fix a broken solder joint on (intermittent loss of tx..)give the radio a tap it would work for a while..while soldering points i shorted out a trace.which burned r194..fixed shorted trace replaced r194 with same value..now the radio throws out a very low deadkey (half watt)..without keying the mic..if you key the mic you get your regular deadkey (3 watts)..swings with modulation..of course the radio has no recieve becuase its always in tx..any and all help would be appreciated..
