Courier Galaxy Problem
Is the tx led lighting up when you depress the PTT? If not, your keying transistor needs replacing. If it is lighting up then check your voltage regulators for your amp and mixer stages.
This is generic info as Im not 100% familiar with that rig.
  • @ wavrider:
    sea que sea que,
