BJ radionut
Supporting Member and 6m addict
Mkube: If you watched that video, you've seen just how easy it will be to get on the air from a camping site.
Find a picnic table to set radio and tuner on. Hopefully under a tall tree.
Take single wire (60ft long +/-) straight up as high as you can get it pull any extra to another near-by tree (inverted "L" shape) but that's not even critical.
The whole wire can slope from op station to any tree or support as long as it's high enough that someone does not choke or trip over it.
Ground: Short 2 or 3 ft copper tube with end flaten pounded into ground close as possible to radio and tuner. Pour some water around it!
Connect everything correctly...Tune up and your ON.
I have done that so many times, I can not even count them....
Problem with dipoles camping to do it right...(3) support locations! Dipoles work poorly if center feed location is lower than ends...
Plus and you said 80m operation with dipole....That's 120ft long!
Even 40m takes almost 70ft of space!
I don't know to many camp grounds where you have that much space, without running the antenna through someone else's spot...
You can always add counterpoise wires to the ground rod or tuner to improve things...but I have worked the world , doing just how I have explained and QRP...let alone with 100 Watts.
Enjoy
All the Best
Gary/W9FNB
Enjoy
All the Best
Gary/W9FNB
