Does Size Matter. . (Bridge Rectifier)
Low_Boy
Jan 21, 2010
1,931
1,193
173
Rochester N.Y.
Both are 200V 6 amp. The one in the radio is twice the size as the replacement. Should I look for something a bit bigger in size or will this small one work properly?
Thanks
Low_Boy,
Though the new Bridge Rectifier is smaller it should get the job done. Newer Electrolytic Capacitors are smaller than older ones. A sign of improved technology I guess.
Having said that, I replaced the Bridge Rectifier in my 139XLR last year and ran into the same issue. I opted to go with a physically larger rectifier. I did initially order a smaller (physically) rectifier but reasoned a larger device would spread heat better/faster. I used an MP802G but initially ordered an NTE5313.
David
