It looks like its designed around this mosfet.Likely this, but does not come with output transistors or heatsink.
1200W 1.8-54MHz SW Shortwave Power Amplifier Board MRFX1K80H BLF188 Power Amp | eBay
Find many great new & used options and get the best deals for 1200W 1.8-54MHz SW Shortwave Power Amplifier Board MRFX1K80H BLF188 Power Amp at the best online prices at eBay! Free shipping for many products!www.ebay.ca
You will want the input attenuator, you really don't want to overdrive those devices.Still requires the antenna relay, bias switching, input attenuator (probably) ..........
And for those who are thinking about building one the copper board runs aboutActually it needs a copper heat spreader. Aluminum has too much thermal resistance per square inch for a 300-Watt transistor that size. Copper, however, will absorb more heat per square inch. The much-larger surface of the spreader plate against the aluminum heat sink surface will carry the heat to the aluminum heat sink.
Most any RF power transistor rated over 150 Watts requires a heat spreader.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
