DX2547 10 meters
yeah you are probably right.
is there such thing as a PLL swap? like taking a pll from a 10 meter export and putting it into a cb?
The DX2547 won't work very well if at all on 10-meters because the main pcb isn't designed for that frequency range. I'm not saying it can't be done, just that the radio will not have very good specs at the frequency range.
Maybe a higher value crystal would put it on ten meters.You'd probably be better off getting a 10 meter rig.
Ok that is a good idea but how would i go about hooking up all of the controls to it??? the export i have. and SS3900 would work fine but what about some of the chassis controls. especially the frequency counter i would definatley want that to be hooked up.
  • @ nomadradio:
  • @ c316buckeye:
    no conditions in ohio
