Hello all. Quick question. (I know, you are saying, "This is EBAYGUY, he types books, not quick questions"! Anyway, I will try.
I found a TX-RX, meter color change mod. The meters are one color on RC, and another color on TX. The only problem, it was on an RCI-2980. Even though they are the same board, it cannot be done in the same place. I emailed Ranger(RCI), and they were very helpful. They gave me the two points on the board to do the mod. Problem being, they will be attached to the 2SB525 transistors.
Question is:
If this will not take power from the transmit, which leg do I solder to? I can see where the ground is, but not sure about the other 2. I can't find that Transistors datasheet online. It is too old!
I can, and will post a How-To guide with pics when I have time to get this complete.
Thanks,
Lenny
Question is:
Thanks,
Lenny
