This amp is in great condition.Just dont use it anymore since I got my Ameritron AL80b.The pre amp on this has always had an issue.Works when it wants to.I never used it anyways.Amplifier works great.My #'s vary from the info below.I was seeing 350 to 500 depending on the radio I was using.Keep in mind though I dont own a radio that exceeds a 4 to 1 ratio.So if your radio swings more than mine,then you'll probably see the bigger #'s.
The amp pictured below is a pic from ALA.My camera is not working.
PRICE IS $300 plus actual shipping of your choice-USPS M/O only
Fatboy 600 Watt Base High Drive, Class AB
This amp is gold or SILVER in color. This is a four pill, base station, 600 watts, linear amplifier. It has AB Biasing, so it sounds great and works excellent on SSB. Just plug this amplifier into the wall and start talking. It contains its own power supply. It is designed for base station use at home, for 110-120 volt A/C.
WORKS GREAT WITH AN EXPORT OR TEN METER RADIO
- Can input 15 watts deadkey and 50 watts swing.
- Single Side Band switch
- Pre-amp to amplify recieve
- 4 x SD1446 Transistors
- Automatic Fan to keep amp cool during long key downs
- Dimensions H 6 x L 12 x W 8
- Weight is 20 pounds
- Class AB: Works perfect on FM, AM, SSB and CW
- On/off Switch
- LED on/off Indicator Light
- On/off Switch
