FERRITE CORE PERMEABILITY
unit_399
EL CAPO
Jun 17, 2008
2,129
3,044
273
ALEJANDRIA, COLOMBIA SA
How can you determine the permeability of a ferrite toroid core? I want to construct a 2:1 current balun. I have a box full of toroids, but have no idea of their permeability. They are various colors, mostly red, yellow, or blue.
Anyway, is the core material that important in a balun, or will any core that will handle the wire size and # of turns I need suffice? There is a lot of info online about baluns, but none I've found talks about how permeability affects balun performance. I want to use this on my 2 element quad to replace the RG11 stub match I'm using now. I never exceed 300w pep on my rig, and will be using #12 enameled magnet wire for the windings.
Any help and suggestions will be greatly appreciated. 73s
- 399
I'm pretty sure this is determined by manufacturer specs based on the core materials used. If you know the manufacturer and part/model number of the cores you may be able to find the data sheets on the cores.
Otherwise you need a piece of equipment most of us don't have on the bench. If I were you I'd just start building and see how they work.
The cores you are describing are Iron Powder cores, which will work fine for your low power application. Higher power devices would work better with ferrite cores, which are all dark gray in color. It would be best to know the permeability from the manufacturer. Here is a hint to determine a cores permeability: Equation for Permeability of an electromagnetic core.
Here is the Palomar Engineering and the Amidon pages to help you determine the values of the Iron cores you have.
Amidon: https://www.amidoncorp.com/pages/specifications
Palomar: Iron Powder
I hope this helps.
73,
Mike
KQ6F
The way I determine permeability (mu) is to kinda back into it. I take the unknown core and wind 10 turns of wire onto it and measure its inductance with a LCR meter. Then I determine its value A (uH per 100 turns) from the formula: A = L x 10000/N(squared), where L = measured inductance for N turns.
Example: for a given FT-50 toroid with 10 turns, I measure 5.9uH. A = 59000/100 = 590. Looking up specs for FT-50 ferrites, I find that FT-50-43 has a nominal A = 520 with mu = 850. This apparently is a FT-50-43.
