W
W9WD
Guest
Anyone know where I can find a cheap piece of fiberglass 2" diameter rod about 2 feet ought to do it. Maybe 18"
Part of a 5/8 wave antenna to isolate the vertical element from the mast
Fiberglass shovel replacement handle from Home Depot. Won't be 2" but check them out and see if you can make them work for you.
MAX-GAIN SYSTEMS, INC. : Fiberglass Price List
I bought some from these guys a while back. They have every size, type and length. You don't need 2" in diameter for your project...I bought some 1" diameter solid stuff that is unbelievably strong
BTW, these guys also have fiberglass push up masts.
