FT: Palomar 350Z amplifier
Status
Not open for further replies.
ExitThirteen
Grumpy and Cranky
Apr 18, 2008
1,968
1,679
173
Cornpatch of Iowa
I recently took this Palomar 350Z linear amplifier in trade from a ham operator friend of mine that was wanting some SSB CB equipment for his shack. He worked 40 and 20 meters quite a bit, so I know this amp functions on those bands. I put it on a dummy load and found that it does do just about full output (325-350W on my Bird 43A) on all bands. Currently has 6LB6 tubes in it. I have 5 more 6LB6 tubes that go with it, but they are untested. This box is not pristine, but everything seems to work okay. The preamp DOES work, but the relay is a little dirty, and sometimes the preamp doesn't come on right away. The preamp switch has been replaced at some point (it has a center poition on it that is not used), but it works as it should.
I'm looking for a solid state base amplifier. Would like to have something around the same wattage. Would also consider a 50-70 amp power supply as well. I like the sound of tubes, just don't like all the loading/tuning. Post or PM what you may have, let's make a deal!
Here's some pics of the amp.
Heya Mack, and Triple9... Sorry about not getting back to you two sooner, been away on business this past weekend.
I got what I needed locally from someone in my SSB club, so I don't need to swap out an amp or power supply for the Palomar. However, to be fair, I will put it up for actual sale, if either of you two are interested. I would like to get around $200.00 shipped for it, but I'd entertain offers too.
I don't want either of you two thinking I was double dealing behind each other's back, so I wanted to post here, and let you both know of the situation. Thanks for your patience!
~Cheers~
~Cheers~
Thanks.
Status
  • @ nomadradio:
  • @ ShadowDelaware:
  • @ c316buckeye:
    no conditions in ohio
