FTM-350 set mode APRS
dli009
Jan 31, 2010
9
Hi I have a question as yaesu FTM-350 set mode WIDE1-1, WIDE2-2 or WIDE1-1, WIDE3-3 in the menu, I see only WIDE1-1?
The manual is very bad and very little information there
On Menu E19-Digi Path Select - You can change it from WIDE1-1 or WIDE1-2,WIDE2-1 or custom paths. If you want to change it to something like WIDE 1-1,WIDE2-2, you're going to have to us a custom path like PATH 1. Then you would go down to the DIGI PATH 1 menu and punch in your custom path.
