Galaxy 95t2 changing Transistor Q54
I have did many, and delt with that ebayer member and bought many items off him...not a bad guy!!!!
now to the point...that is not only a replacement but if you change the caps in that area you can get a bit more power...but without the caps,that transistor is a upgrade for when you change the final and open up the modulation..
the board can handle the stress a bit more with that transistor..
so it is well worth it:)
BTW...2SB754 is a 60-watt 7amp and the 2SB817 is a 100 watt 12amp so this makes it way more then Just a replacement!
Enjoy!
  • @ Tim Chambers:
