Galaxy Maleka
cbshack
173
6
Central Florida
I am trying to repair one of these radios. I can get good receive and tranmsit on about 50 channels or so. It can be band AB, C, D, or band F. It is a 3600 board. Even on band D which is CB I can cover 40 channels and then about 10 or so into band E. It only seems to recieve and transmit properly on 50 channels no matter how I tune L44, 43, 42, 40 and 33 I believe.
Thanks for the help.
VCO issue. Not locking across the entire range. Perform a full alignment, according to galaxy service manual / galaxy spec's.
--Toll_Free
Ditto. You won't know if its an alignment issue or a part failure (or other circuit failure) until a full factory alignment is done. Many times the fault will make itself known during the alignment process, narrowing your search scope considerably.
