General Lee Alignment info
Cheech
716
6
35
Medina county Ohio
Looking for the full alignment info for mosfet general lee. One of the local hack shops had their hands on it and its pretty screwed up!
Also was wondering why the voltage regulator is getting extremely hot?
check the bias voltages and make sure the dead keys are not set too high. this can cause the components to get hot if set too high.
I set the bias voltage. It was set a bit high. Dead key on low is 1 watt and on high its 4 watts.
The AM Mod amp transistor is still getting really hot. Even at a dead key it heats up to the point you can't touch it.
  • @ nomadradio:
  • @ ShadowDelaware:
  • @ c316buckeye:
    no conditions in ohio
