GMRS Base Station
Here we go.....
KingCobra_CDX882 said:
Isopheric antenna..
Isotropic maybe?
oh and although a 1/4 wave is broader banded then a 5/8 wave
Nope. And, I'm not talking about broader bandwidth, I'm talking about signal pattern. I don't care what the frequency is, sometimes a 5/8 wave is undesireable. This is a perfect example since he is on the side of a mountain.
now that we are talking GMRS aplications/frequency's..I hope we all know these are simply line of sight (for most part) Therefore Higher Gain is always desired and even needed if one wants to Know they will get though..
No again. It is NOT desired or needed in this application. A broader signal pattern will travel up and down the mountain better than putting the signal right into the side of the hill.
when i use my High Gain (at GMRS frequencys is about 10-11 Dbd gain) and whether i am talking a half mile or 80 miles away i Know i will get though..
Are you on the side of a mountain and only trying to talk 2 miles away? No? Maybe now you are beginning to understand!
but in my case i do not have the problem of mountians being in the way..i am in a city....where a 1/4 mile away i do have 2 buildings maybe 40 feet higher then my antenna....otherwise is about 3 miles before mahatten has any higher buildings..as a result i easily sail over those minor hight obstructions..and when i use the beam...forget about it...lol
He is! He is! He is beginning to get it!
if i remember...You said where you want to put the base or mobil-base radio it will be half way up the mountian..
Now hight matters even more then Dbd Gain..If you were on TOP of the Mountian...Then i would say go with either the High Gain Db 5/8 wave antenna or a ok 1/4 wave low gain antenna..
Then you would want an antenna with downtilt! If you don't have downtilt, then the 1/4 wave antenna would work better for the stations closer in and below the transmitter. The 5/8 wave antenna would shoot right over the locals heads!
If in your Aplication...You at the base are higher then anyone else you would be talking to are...
then is still ok i suppose to use a low gain 1/4 wave..
HE GETS IT!!!!
if though others on those portable Blister Box GMRS radios are higher then you (sometimes or always) then sick with the 5/8 wave High Gain Dbd antenna..
Damn! He doesn't get it.....
the best of course is to have both hight and High Gain Dbd antenna..
Not always, and this is a perfect example.
