Heathkit Service Bulletins: GR-78 1970-84
AudioShockwav
Extraterrestrial
Staff member
Apr 6, 2005
9,071
8,911
593
Nor Cal Sierra Nevada
Fri, 3 Apr 1998 08:20:26 -0800
Messages sorted by: [ date ] [ thread ] [ subject ] [ author ]
Next message: Gary Harmon: "Scope Kit & SB-220 Plate Xformer FS"
Previous message: Richard Hall: "AA-21D schematic wanted"
February 9, 1970
GR-78 Bulletin No:
Transistor General Coverage Rcvr GR-78-1
Rocker Switches
[PN 60-45] S.P.S.T. switch is being replaced by [PN 60-48] D.P.D.T.
switch with improved contacts. Four of the six lugs are removed when it
is used as a S.P.S.T. switch. The new improved contact switch [PN 60-48]
will also be used to replace the [PN 60-32] D.P.D.T. switch.
August 11, 1970
GR-78 Bulletin No:
Transistor General Coverage Rcvr GR-78-2
GR-78 Modifications
Band F Oscillator Problem: OSC. BOARD
1. Remove existing osc. FET and discard [PN 417-207].
2. Replace with MPF-105 [PN 417-169]. SS hole will not be used.
3. Remove and discard R300 [100 ohm] and run white wire directly to hole
#1.
4. Remove and discard R305 [10K ohm] on foil side of board.
5. Remove and discard R304 [10K ohm] across Band F coil L306. Replace
with
2.2K ohm 1/2 W [PN 1-44].
6. Drain voltage will now be 9.6 volts DC or slightly higher.
MIXER BOARD
1. Remove and discard R203 [1000 ohm 1/4 W] and replace with 5600 ohm
1/4 W
[PN 1-26-12].
2. Remove and discard R204 [5600 ohm 1/4 W] and replace with 22K ohm 1/4
W
[PN 1-45-12].
***Oscillator trimmers will have to be re-adjusted slightly.
500 KHZ CRYSTAL CALIBRATOR
Replace C402, 68pf with [PN 21-21] 200pf disc. ceramic. This change
assures
oscillation.
FRONT-END AGC
Replace C419, .05mfd disc with [PN 20-102] 100pf mica. This change
provides improved AGC and also improves distortion.
Also replace C511, 10mfd electrolytic on terminal strip with [PN 25-123]
2 mfd electrolytic.
FILTER PASSBAND
To improve passband, make the following changes:
Replace C406, 100pf mica with 3300 ohm 1/2W resistor [PN 1-14]. Stand
resistor on end.
Remove and discard C413, 100pf mica. Replace with 3300 ohm 1/2W resistor
and .05 mfd disc in series. Stand resistor on end.
HUM ELIMINATION
While using whip antenna indoors and power cord plugged in [charging].
1. Remove and discard C508 and C509 [.001 mfd line by-passes].
2. Remove existing 2 wire AC receptacle and replae with 3 wire
receptacle
[PN 432-76]. Run wires from new receptacle to existing terminal strip.
3. Replace existing 2-wire line cord [PN 89-3] with 3-wire cord [PN
89-30].
March 23, 1973
GR-78 Bulletin No:
Transistor General Coverage Rcvr GR-78-3
Microphonics
PROBLEM: Squealing - howling - general instability.
SOLUTION: Replae tuning capacitor C501, [PN 26-123] with [PN 26-143].
This change will go into effect with level 11 production having series
numbers [11----] or higher.
November 20, 1974
GR-78 Bulletin No:
Transistor General Coverage Rcvr GR-78-4
Low Battery Life and Inoperative "S" Meter
This problem can be caused by the "S" Meter terminals shorting to
chassis.
To correct this problem, perform the following:
-- Straighten the meter terminals and then install a 1 1/4" X 1 1/4"
piece of insulating paper [PN 75-108] on the rear of the meter.
April 16, 1975
GR-78 Bulletin No:
Transistor General Coverage Rcvr GR-78-5
FM Interference on Band F
Install the following change to minimize this type of interference:
Change:
1. Install ground spring clip [PN 258-183] between tuning
capacitor
and chassis. Scrape both capacitor and chassis to assure
good
contact.
2. Change R304 across Band F oscillator coil from 5.6K ohm to
2.2K ohm [PN 1-44].
September 27, 1976
GR-78 Bulletin No:
Transistor General Coverage Rcvr GR-78-6
Band F Too Broad at Low End
A resistor change was made in this unit in Bulletin GR-78-5 to minimize
FM interference on band F. The resistor, R304, was originally a 5.6K ohm
and was changed to a 2.2K ohm. This lower value resistor has caused some
units to tune too broad at the lower end of band F. If this complaint is
received, R304 may be changed back to the 5.6K ohm to correct the
problem.
Check the receiver for FM interference before returning the unit to the
customer.
November 9, 1976
GR-78 Bulletin No:
Transistor General Coverage Rcvr GR-78-7
Cannot Align Band E and F
If Band E and F cannot be aligned at the low end, change:
C315 from .1 uf to .05 uf [PN 21-143].
Be sure to check all bands for oscillation after this capacitor change.
November 10, 1976
GR-78 Bulletin No:
Transistor General Coverage Rcvr GR-78-8
Low
Sensitivity
If the sensitivity of the receiver is low and no background noise can be
heard, check for one or more open ceramic filters [PN 404-399]. This
defect is usually caused by excessive heat applied during soldering.
Sometimes pushing on or wiggling the suspected filter will cause the unit
to operate - unless another one is defective.
September 20, 1979
GR-78 Bulletin No:
Transistor General Coverage Rcvr GR-78-9
Oscillator Will Not Align
If you cannot achieve a high enough frequency on the high end of bands E
and F, and also, cannot lower frequency enough on high end of band A; do
this:
- Remove jumper wire from circuit board to top of trimmer capacitors
C305, C306,
and
- Install a 1.5 pf [PN 28-4] or 2.2 pof [PN 28-1] phenolic capacitor in
series, as
necessary for proper tracking.
- Also, install a 24 pf capacitor [PN 20-77] in parallel with C301 if
necessary.
February 29, 1984
GR-78 Bulletin No:
Transistor General Coverage Rcvr GR-78-10
Calibrator Inoperative or Intermittent
Disconnect the lead of C504 going to connector CH on the large circuit
board. Bend the capacitor 180 degrees and reconnect the free lead to the
center lug of connector CF. This moves the output lead of C504 to G1 of
Q201, increasing the level of the calibrator signal and reducing the
oscillator load.
This is all that I hold on the GR-78.
Joe W7LPF/4
