No, they were lightning protection...as frequently pointed out by the operator. Maybe they served two purposes, but I was told multiple times they were for lightning protection.
No - you were told wrong.
Of course, but they have done TONS OF HARD WORK AND SPENT THOUSANDS OF DOLLARS ON CORRECT GROUNDING SYSTEMS. The typical private hobbyist can't do that.
At last something I know about...
All kinds of cool Grounding Electrodes in 250.50- In the National Electric Code.
A horizontal "ground ring" must be at least 20ft long, 2GA and in direct contact with the earth.
You can ground to a chunk of rebar encased in concrete at least 2" thick in direct contact with earth. The rebar must at least have 20 feet of galvanized or bare exposure to the concrete
Sure it can be done, but like you say you have $500 bucks in it. Some of these guys don't have $500 in their entire stations.
And why would anyone WANT to sit around and try and operate through a local thunderstorm anyway? Everyone else is disconnected and you have a receiver full of bad static crashes.
What the heck? .... Disconnect !
so concrete is not a insulator even though it's made or rock , sand , mortar and water ? i wonder why folks with towers on buried concrete bases even bother adding ground rods ?
You'd actually be surprised by some of the dreadful installations. Tower grounded, building AC grounded, but no bonding between the two. The equipment acts a jumper between the two. It's surprising how long the gear lasts.
If the system is designed and installed properly the added cost is next to nothing. Just do it right the first time and you're not spending thousands of dollars. Simple layout of the building and tower are critical. Mess up and the repairs could easily be that much though.
Warren, how many times have we seen a transmitter cabinet sitting directly on a concrete floor with the AC service grounded to the chassis at the bottom and the transmission line grounded at the top or vice-versa? It would cost nothing to do it right the first time but lots of dollars and down time to make it right later.
