HR2510 display works when voltage 8.5
Oct 24, 2008
25
I am having display issues. The display shows all 8's, LCD's all light up.
I figured out that if I lower the voltage of my pwr supply to about 8.5vdc the display works fine. IC312(?), the 7805 voltage reg, has an output of 10v with normal pwr supply input. And it is about 5v with the pwr turned down to 8.5.
Any ideas?
I am not going to send it away to anyone. I am sure I can fix it but I need some ideas. I have sent emails to Rogerbird but he has not returned them yet, I am sure he is very busy.
I have replaced most of the cap's associated with that 7805 AND the 7808 it's attached to. I have also replaced all the caps on the display board itself.
I guess I really need to figure out why the 7805 does not put out 5 volts like it should. I have replace the 7805 as well.
