Mainly looking for trades, antenna tuner? giant spool on wire (so i can build an antenna), maybe a beam antenna? CW key? maybe an old sweep tube amp? hell I am open to anything really
Would consider cash ($175?)
freshly aligned, gets great signal reports, comes with an RCI mic(with an upgrade mic element, channel buttons work)
Everything on this radio works. talkback is removed, mic gain circuit is modded, opened up for 11 meters, external speaker connector, thick wire feed to the final, blue lighted face (easier to rear the display), modded to use a computer hard drive connector for power (still has stock power connector as well.)
(I can add an upgraded final MRF455 if you like, I could even do a dual MRF455 final if you want, as well as variable power, and could also mod the predriver section if needed)
