Here is my situation. where I have the radio mounted, the Wilson 1000's coax length is prefect. But I dont have enough room to get my SWR meter in there. Is there a patch/extender cable I can buy to extend the Wilson's coax ( the patch would have to be female like the radio and then male on the other end ) say about maybe 4'?
I would then remove it once the SWRs are set.... I want to recheck my SWRs again, as I did it at first and the meter showed decent ( 1.2-1.4ish ) but again I want to recheck, but I need to extend the coax a bit.
edited: Maybe I can get a 3' patch ( like used on the swr meter ) and run a so-239 ( correct one? ) female to female connector? Then just run that from the: wilson coax -so-239 female to female- 3' patch - into swr meter - out of swr with 3' patch into back of radio?
that would cause any issues with coax length and SWR right?
