johnson messenger 223 frequency adjust
I LOVE the 223's. I have rebuild tons of them and owned over 20 or so. The grid leak mod is good advice, although I didn't use the same value, but the end result is the same. I also would so some mods in the final output section and modulator section as well.
If you need a 32.9 rock, lemme know. I am sure I have a few that are good I can send to ya, free of charge. PM me if interested.
As far as expanding the channels, you can, buy why? It is a pain, there is no way to do it other than a external VFO or changing crystals. Even then, with the above mentioned mods, I would usually just restore them, and most of the older radios I have owned back to factory specs for the purpose of nostalgia and call it a day.
Hello---Justin' Time.
JustinDePolis, killowatt21@aol.com, send contact info, I would like to ask your advice on a Johnson. Thanks, JT
honestly, that site is not very good nor is the communication from them. i placed an order and waited and waited and finally figured they were out of business. i emailed them to cancel it. then i got a reply saying since i needed a quote they would get around to it when they wanted. needless to say i wont order from them nor recommend them to anyone. just my opinion. again just my opinion. no need to tell me im a bad person for not liking their way of doing business. what i did do was pick up a parts 250 that had all good crystals for 10 bucks and used the parts from that radio. worked like a charm. everything is on freq and the radio works great. with the exception of the meter but no one has come up with a fix for that one yet. yes, to answer your question that is the crystal you need
Ken is an oddball to deal with on the phone and hes just as bad in person as he is on the phone.. I only order from them if i REALLY REALLY need a part. They also don't like to take debit cards and credit cards when you go to their shop in person. I found that out the hard way! They are VERY old school about a lot of things..:headbang
The operating frequencies in the Messenger 223 are generated by mixing the outputs of two crystal oscillators in a 6 x 4 switching arrangement. The crystals control the oscillators and there is no provision for adjusting individual crystals. Chances are there is only one bad crystal. Give me a list of the channels that are off frequency and the actual frequencies you are reading on these channels. I will try to tell you which crystal is bad. Replacement crystals are readily available.
As for the mike plug. Pin 5 on the stock connector is not used, so simply connect pin 1 on the 5-pin to pin 1 on the 4-pin, 2 to 2, 3 to 3, and 4 to 4.
- 399
I have the same problem with my 223. 17,18,19 and 20 are dead. Also9,10,11 and 12 are out. If 17-20 are a 32.90 crystal what would be the 9-12 ? Did we decide Ken's would be the best place to buy? Thanks for the help! Bert
Good point! Best to use either the original Johnson mike, or any Hi-Z crystal mikes. An unpreamped D-104 will work well. (Small mod: change out the grid-leak resistor of the mic preamp to 5 megohms, and that D-104 will sound wonderful.)
What is the grid leak resistor and where is it?
Thanks!
Just happened across this thread and I see no one answered your question. If you are using the original schematics, that resistor is R22 and if using a SAMS CB-23 schematic it is R44. It is on the grid (PIn 2) of the 12AT7 mic amp tube. It's a 4.7 meg resistor.
  • @ nomadradio:
  • @ ShadowDelaware:
  • @ c316buckeye:
    no conditions in ohio
