Hoping someone can help me out with a NO MODULATION CURRENT issue. The radio keys over 100 watts and shows a good sine wave on the scope. Only issue is ZERO MOD CURRENT. I checked the large tap resistor and it’s showing as good 20K end to end and 9 something and 9 something ends to center.
Put in a new modulation XFMR also as I had a new one. All the tubes were checked and all showed like new. Checked all the caps and resistors in the V1 & V2 area also and changed any that were out of tolerance.
When I received the radio it wasn’t working as I had no oscillator Current and found they had the cap coming off the crystal board going to the wrong pin. Repaired that and everything else started coming into line. Now just the MOD CURRENT ISSUE.
Just not sure where to start looking now?
