Sky Command is AWESOME!!!
You have to use another HT that has sky command feature like my D7AG or even the mobile D700A heck even another TS-2000 or TS-870 yada yada yada,,
Using my HT I can "control" my TS-2000 on the HF bands!!!
Sounds like cross band repeat? ALMOST difference is, I can change frequencies and operate the internal antenna tuner as well!!!
What does that do for me? Well my 2 meter 70cm antenna is 50 foot in the air. My G5RV is also at the top of my tower. So if I were to use my HT I can drive around town with nothing more than and HT and talk on the HF bands or VHF UHF bands all from that little radio but I would be transmitting off my G5RV.
I transmit to the TS-2000 on 2 meter with the commands to transmit on HF or change frequency or tune the antenna and the TS-2000 transmits the signal back to my HT on 70cm. Using this HT it shows the frequency I am on and the mode.
Its a BLAST,,,,,,,,,,,,,errrrrrrr aaaaaaa so I am told <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT="
"> <img src=http://users.joplin.com/dutch64804/rollingaround.gif ALT=":rollingaround">
</p>
