I was going to send the radio to Kenwood service center east. Radio lost power and is putting out less then 2 watts on all modes. Final ? Any other suggestions on repair locations.
Yeah thanks Rob did that and went over the radio with two good meters and a dummy load.Did you try a 'full reset' - yet?
Look that up in you radio's manual . . .
http://www.avvid.com/
I have never used this repair shop but he has a great reputation in the ham community.
I would check to see if you did a full reset again. Been there; done that. Found that after I did the full rest twice that the output power was once again restored. Remember, that these radios will fold back power when faced with a bad load until it is corrected. Check your load out - too . . .Yeah thanks Rob did that and went over the radio with two good meters and a dummy load.
I did the full reset but I can try it again. and see what happens, It would be nice if if works this time.I would check to see if you did a full reset again. Been there; done that. Found that after I did the full rest twice that the output power was once again restored. Remember, that these radios will fold back power when faced with a bad load until it is corrected. Check your load out - too . . .
