kenwood ts480 rs232 cable wiring check?
fodendaf
416
52
38
i engineered a 9 pin serial cable with all pins in parallel ie pin 1 on one db9 to pin 1 on the other db9
db9-db9
1-1
2-2
3-3
4-4
5-5
6-6
7-7
8-8
9-9
ground-ground
i thinks it's right but wanted to be sure. the manual says between comp and radio calls for a straight thru cable but google is overloadingly vague so is it wired right?
  • @ nomadradio:
  • @ ShadowDelaware:
  • @ c316buckeye:
    no conditions in ohio
