KISS-SSB HF Antenna Counterpoise Fact or Fiction
Discussion in 'Amateur Radio Antennas' started by Happy_Hamer, Jun 12, 2011.
  1. Happy_Hamer
    Happy_Hamer
    Expand Collapse
    Administrator
    Staff Member
    Mar 22, 2001
    5,045
    135
    I was scrounging around eBay looking for antenna alternatives while in the field with my QRP rig and found this
    http://cgi.ebay.com/ebaymotors/KISS...910370#ht_2342wt_1167?clk_rvr_id=239878739523
    I was like WHAT THE HELL! $150 for wire?!
    Here is their website
    Home
    So then I started searching for more info on this thing.
    And found someone bought one and disassembled it, with no further data, like wire lengths and the such. The author claims he found seven different wires connected to the one wire for the tuner. And took pictures.
    The KISS SSB Counterpoise - Revealed ( with Pics ) - Cruisers & Sailing Forums
    I joined the forum and asked a few questions there and decided to bring the topic here for our antenna gurus to look at.
    Was Phineas Taylor Barnum correct?
    #1 Happy_Hamer, Jun 12, 2011
  2. sp5it
    sp5it
    Expand Collapse
    Master of puppets
    Jul 9, 2009
    791
    322
    [​IMG]
  3. AudioShockwav
    AudioShockwav
    Expand Collapse
    Extraterrestrial Admin
    Staff Member
    Apr 6, 2005
    5,400
    1,100
    Yes, I agree 100% with SP5IT.
    Can there even be $20.00 worth of Material there ?
    7 Radials, a 10 foot chunk of hose and some RTV to seal up the ends.
    Even at that I am not sure how well it is going to work after you bunch up the wire and shove it in the hose....seems to me you would be better off laying out the radials full length.......... ??
  4. NorthStar
    NorthStar
    Expand Collapse
    Administrator
    Mar 21, 2005
    1,353
    26
    I purchased a MFJ-1964K Kit and I am building the AD5X Portable HF Antenna for 10-40 .
  5. AudioShockwav
    AudioShockwav
    Expand Collapse
    Staff Member
    Apr 6, 2005
    5,400
    1,100
    I also find it hard to describe wire folded back on itself and shoved in a tube as a " marine sealed coil "
    Seems a bit off to me.
  6. C2
    C2
    Expand Collapse
    Aug 3, 2005
    2,409
    64
    It's like a big tank circuit. Probably not the best, but I'm sure it does exactly what it was designed to do...make someone some money.
  7. Sean McDonald
    Sean McDonald
    Expand Collapse
    New Member
    Sep 2, 2014
    On our sailing vessel we used the conventional 75 plus feet of copper foil for a couple of years and then thought we would give the kiss-ssb counterpoise a try. The difference was like night and day, everyone in the nets have commented on our "new radio" but I had to just tell them it was the new counterpoise. My hook-up speeds through the Pactor Modem to both Sailmail and Winlink are a lot faster now also. The stray RF onboard is even gone, no lights flashing and the auto-pilot does not go crazy when I use the SSB. It may be VooDoo, but it sure has helped us, and many others we know out here cruising on the boats. I even knew of a guy that used a wire in a fiberglass flag pole and the kiss-ssb in a loop at the base covered by decorative rock and is working the world. Count me as skeptical and then converted over.
    Robb likes this.
  8. wavrider
    wavrider
    Expand Collapse
    Jun 2, 2009
    3,160
    919
    It is what it is described as, a simple counter poise. It is not voodoo or magic.
    Any op with a simple understanding of antenna theory knows that the radiating element needs the other half of the antenna to function correctly.
    Without the "other half of the antenna" IE counterpoise, The RF radiated from the radiating element will look for anything and everything to use as the other half IE coax, ships wiring, etc etc.
    A simple artificial ground from MFJ can be purchased on the used market for around $60.00 a random piece of wire attached to it tuned properly no TVI RFI and ALL OF THE CROWD WILL compliment you on your new radio.
Share This Page
Members Online Now
  1. kopcicle,
  2. dave457,
  3. Onelasttime,
  4. CrazyFin,
  5. sonoma,
  6. LeapFrog,
  7. Ariel,
  8. Peicsinc,
  9. Middleman,
  10. Robalo,
  11. Ranzo,
  12. Robb,
  13. 4ZERO99
Total: 242 (members: 13, guests: 159, robots: 70)
