Larson 3rd brakelight antenna mount
my ford ranger i just took the brake light loose and drilled a hole and installed a mno mount and used a old speedo cable to run coax thru cab roof and pillar to behind seat,,, and because there was a slight lean back i bent the whip some to stand up,,,
