Little help for a new guy
rockenranger
Dec 17, 2011
104
3
51
I am new at the ham stuff. i got my ticket last december. i have a icom 2 meter mobile set up as a base. i have a tram dual band antenna about 20 foot in the air. i can hit alot of repeaters where i live real good but some are weak. my question is should i put up a beam to help me get the week repeaters better or would going higher with the antenna i got now help
thanks
line of site will help alot
so yes higher is better and you probably have some noise and static in with you so the beam will be a little more directional and help quiten down the repeater
I know it's a 14 element 2 meter beam. It certainly should 'hear' better than your omnidirectional antenna! Now the only 'trick' is pointing it in the right directions. Hope you've got a good rotor. :)
Something that I had to learn personally after others told me (I just won't listen). Its the feedline for VHF needs to be of the best size and quality that you can afford.
