Looking for a few transformers
I have some transformers from KLV-1000's. You can check the schematic and see if it is what you want.
  • klv_1000.pdf
Reactions: Rwb
this
For external base use supply requirements are:
6 volt AC or DC = 4 amps (filaments) or 12 volts = 2 amps
300 volts DC = 100 ma (30 VA)
600 volts DC = 300 ma (180 VA)
These ratings will give full 60-watt input and give a slight amount of headroom on transformer spec ratings.
  • e_f_johnson_viking_mobile_transmitter (1).pdf
