Looking for a possible tabletop receiver
Matthew Lawson
New Member
Jul 18, 2020
3
37
Hi, I'm fairly new to shortwave listening, having a CCrane Skywave SSB radio only and I'm thinking about purchasing an Alinco DX-R8T.
A few questions.
First of all, what is your experience with its performance? Does it perform well? Would it perform well in a electrically noisy room with a good antenna outside?
What type of connector connects to the antenna jack? What is it called?
What type/brand of antenna would you recommend for it and for easy install? Would it require power or grounding?
What if a high vertical antenna is not an option?
Could you use the MLA-38 loop antenna with it?
Thank you for your help! I'm fairly new to this, so I have alot of questions! Take care.
- Matthew Lawson
Thank you, Gary!
I looked through your links. Could you explain the links to me? Is dxengineering.com where you would buy one?
What about the palstar? I like the price of the Alinco.
What about the quickstart and kv5r links?
A few questions.
- Matthew Lawson
Welcome! You found the right place. Lots of smart people here who are willing to share their knowledge. I have learned a lot in my short time here.
Chris
Reactions: Justme
Thank you. A few more questions. Does the Alinco DX-R8T I mentioned have FM Broadcast band in the Receiver model? I'd like to listen to FM too. Or is it just the DX-SR8T that has FM.
Also, would you recommend me buy it from Universial Radio or DXEngineering? How about Ham Radio outlet?
Thanks!
Thanks!
I can’t answer the first part. But the second I’d base on likelihood of future purchases.
Just a thought, but if you are going to spend the money for the Alinco DX-R8T receiver only version....
I'd spend a little more and get the Alinco DX-SR8T... same Receiver (covers 135KHz to 30MHz in all modes), but with Transmit capability... if required.... and can be modified open for TX from 1.8Mhz-30Mhz
Matthew's question is pretty much mine. Since the Alinco is not available, what else would be a good beginner SW receiver? What about the Eton Elite 750?
I'm looking for world news and entertainment, mostly.
As to antenna, I'd prefer to keep it in the attic; partly a privacy issue, but I do have an HOA, of sorts. I have a 5/8ths wave CB antenna with ground radials in the attic already. How would that work for SW reception? I believe I how an SWR under 1.3 across the CB band.
A receive antenna doesn't care what the SWR is. You're compromised with that antenna for CB, but connect a good receiver to it and you might be surprised. Remember, if Marconi had worried about whether his antennas would "work", we probably wouldn't have radio as we do today. Experiment!
  • @ nomadradio:
  • @ c316buckeye:
    no conditions in ohio
