Looking for some RCI parts...
Blackcat630
Apr 2, 2013
1,151
1,858
273
Central Illinois
Well the vfo/channel knob on my DX2527 was doing the jump all over the place thing when turned. So for the last few years I've been using the up down buttons on the keypad. Well the buttons started sticking. I figured the rubber buttons had separated from the backing causing this problem. I finally pulled the trigger and tracked down a new replacement vfo. I changed it out last night no problem. The rubber button pad is fine but the actual buttons on the board are shot. I was hoping someone might have an old junk 2950/70 2527 or galaxy turbo button board I could buy or a couple of the little buttons off the board they could turn loose of. I know one of you guys can help me out. Thanks! 73 God Bless
they did not have any on ebay a few miutes ago when I did a search. but they should have the parts you need if you give them a call. they normally have the key pads new for what people are trying to get for the used ones.
Reactions: Blackcat630
