Low Pass filter?
DXman
Yes, that's 3100 degrees F. Nine yrs of hard work.
Apr 5, 2005
1,734
1,206
173
76
West Coast - Washington
Gentlemen.
I have a Drake 1000 Low Pass-1000 watts below 30 MHz, attenuation better than 80 db above 41 MHz. At times I will come thru my T.V. speakers & picture, but not all the time, I have hooked this filter up directly to the back of the radio when the TVI is happening and the filter does nothing. This is on regular TV antenna on CH 5 and 4.
Next question; I am also on a Dish system which the dish is located about 8 ft from the tower. There are times that when I turn the rotor to move the beam the signal is blocked out on the dish. I am thinking maybe RF is coming from the rotor and causing this problem. I have three ground rods off of each leg and # 2 bare cooper wire plus a continuious wire connecting all three rods. I do have sandy soil, so maybe I am not getting a good ground. What you think?
</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showLocalUserPublicProfile?login=dxman>DXman</A> at: 4/18/02 4:45:07 pm
Gentlemen.
