So I have an m4v here that some idiot decided to over drive with a 2995 first off So need to find out if I
can by pass the driver section first off. At least till I can dig up another 455 it only has one I has a switch on the back that says 4 or 10 watt drive. The bigger issue is the 3 position rotary switch at the front was removed by this jack ass and the resistors that went with it. I just have two pieces of mini coax laying there what can I do about that would an old am ssb switch out of a radio work and how do I hook it back up to make it work?
I would even really be ok just using it as a straight 8 I'm guessing it could be driven behind a 2970 or something then.
