Hello to all. I have a question about mounting a bean and 5/8 ground plane.
My rooftop is 32' above ground, I am using 32"x32" non penetrating roof mount with 8 30lb
cinder blocks for support.The mast is a 1/58x10' chain link fence post. Mounted on top will be
a Yeasu 450 rotor. Out of the rotor is a 15/8x4' mast. 12" on mast will be thrust bearing, 12" further
up a Maco 103c beam is mounted and at 4' or top of mast is a Hy-Gain penetrator 500 minus ground rods.
Both antennas will have separate Bury Flex cabeling.
Does this setup sound workable?
Do I need further separation between antennas?
Thanks,
Bob
Thanks,
Bob
