that depends on the mike ya were using.Carl said:there not very loud, there lower powered. quality is so-so. they lose alot of there versitility when you convert them (no more offset abilitys). they a pain to turn on and make go into cb channels again. converting them is pretty easy now as they added a jumper to the new models. you turn them on they always revert to 10m frequencys. you press the func key than hold the call key for 3 seconds and it converts to cb use again.
they are the old syle magnums, they have been around for years. are they worth the price? a used 2950 for the same price would be a better radio hands down. there small and they look nice. there cheap but even fully tuned they sound pretty wimpy.
I've done a lot of searches on the 257, and that's what I keep reading about. I know they're not audio monsters, but I just don't want to replace one noisy radio with another one. I wish I knew someone locally that had one, so I could try it out to see if I can live with it.undertaker said:My 257 does not have a noise problem thats kinda wierd...
Bobby
But Richard at 8541 electronics tuned it years ago...
I had a midland 79-290 mounted in the dash, and took it out because of noise, but the magnum will fit in the same spot perfectly. For the time being, I'm using a Grant XL, just leave it on the passenger seat, lol. There's no where to mount a radio in my vehicle, except in the dash, under the stereo. It's a 95 toyota 4runner with a moon roof(no ceiling mount) and 5 speed(no under dash or hump mount).Butcher318 said:What radio do you have now?
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
